3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Charging in Parallel and discharging in series capacitors?
Most people (okay, well tech guys :P) know that if you put 2 identical capacitors in series you can double the voltage they can handle and you cut in half the capacitence. These 2 capacitors together have 2x the Joules as one capacitor alone. But if you charged them each seperatly, and then connected them in series, would they have 4x the joules as original? For example, lets say I have a 16 volt 100uF capacitor, if each was charged in parallel to 16 volts and then connected in series, when discharged would it have the same amount of power as a 32 volt 100uF capacitor, or would it still have the same power as 2 capacitors charged in series (from a 32 volt power supply)? This question seems kind of stupid, but using what seems like good logic (or bad if your on the other side) you could argue this both ways. But there's only 1 right answer.
Jul 17, 2009. 1:43 PMfrollard says:
As kelseymh says: conservation of energy - you can have more 'pressure' (voltage potential) at a cost of 'volume' (amperage) total capacitance (equivelant to wattage) would remain the same. You can have twice the energy for half the time, or half the energy for twice as long. Placing them in series makes them cancel each other's 'total volume' gain out by operating at a higher voltage.
Jul 17, 2009. 1:10 PMkelseymh says:
"Joules" are units of energy. You should be able to answer the question yourself just from energy conservation :-)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
