Cheap ways to be able to record guitar/bass on a computer?
I am not looking into investing in an audio interface or an extremely expensive microphone at this point.
I am wondering if it would be possible to make a ¼" jack to USB cable or a ¼" jack to headphone cable or something like that so that we would be able to plug our instruments directly into my computer (MacBook V 10.6.8) to record and edit with Garageband.
Thanks!
-Tqwerty
Visit Our Store »
Go Pro Today »
In reality, it's cheaper to buy a USB audio interface than it is to buy an new MacBook.
You might want to look at some of my sound instructables here. It's more or less for people starting out in live sound, but there might still be something in there that you learn.
Good luck, but be careful.
The only problem is that now I'm skeptical about the safety of my precious MacBook.
If I can find one cheap enough, I'll buy it.
If not, maybe I'll try plugging it straight into my computer.
http://docs.info.apple.com/article.html?path=GarageBand/5.0/en/22893.html
I'm just afraid to blow my sound card.
I just realized that my Mac does, in fact, have a line-in jack.
There are a lot of reasons not to mic amps when you are just getting started with recording. 1. Cost. It will cost a lot more to get a mic that will actually sound decent on an amp than it will to do a line in recording. 2. Noise. Until you've learned to isolate noise, mics will pick up noise around them that a line level recording will not have. 3. GIGO. Depending on how good your amp is, it will only sound worse on the recording. 4. Recording is not live sound. Micing amps is mostly a live sound technique. Most recording professionals will not want to mic an amp because it just doesn't sound as good on a recording as it does in live sound. (Personally, I don't even like the technique in live sound! My rule of thumb is not to mic any kind of a speaker, unless I have no other choice.) You can get the same effect with a little bit of know how a lot cheaper once you have gained some experience editing audio.
No matter what, if you are using a computer for recording, I recommend getting a professional audio interface. It should have both 1/4 in. and XLR, because it will serve you better as you get nicer equipment. It will be cheaper to get the USB interface and use regular microphones than to try and buy USB mics. (Assuming you will eventually buy more than one.)
If you must mic an amp on a shoestring budget, get a large diaphragm condenser mic. It will give you the best sound than any other mic in your price range. Feel free to ask me if you need help choosing a mic, but I would still suggest doing a line in recording.
I understand that if you're going to invest in a microphone, it's going to have to be really expensive, and as a band that's just starting out, we aren't ready to put in ALOT of money.
I did line-in recording with my keyboard just today (1/8"-1/8"), and I have a feeling that even though electric guitars are louder, I'm probably going to try it anyways.
I'll be very careful :3
I find it quite funny that you just automatically assume I am male, though.
Regarding GarageBand vs. audacity, I choose audacity since it's universal, so if I have to tell someone how to do an edit, they can do no matter what system they use. That's the only reason I choose audacity. (Also, I hate macs... So that might have something to do with it!) :)
(How can you hate Macs?) :P
And in terms of viruses, macs have had some decent viruses ever since OS X came out.
Basically it all comes down to how much you know about computers. If you can protect yourself, then you will not have problems on either system. If you can't protect yourself, then you should either learn how, or else use a system that practically no one else uses. It just isn't worth it to crackers to write malicious code for a system that no one uses.
(I'm just getting stated with my mac vs. PC arguments... if you really want some lectures on the advantages of PCs, feel free to ask!) ;)
"I like Macs just because I do."
Isn't that a lovely argument?
I think the best argument that people use is that they like macs because it just appeals to them more than PCs. In that case, it's a personal preference, and no one can change your personal preference, nor should they try. What I hate is when someone tries to tell me why I should like macs. I just don't. That's my personal preference, and I can back it up logically, but I should have to.
Anyway, I wish you the best of luck with your recording, and if there is anything I can help you with, don't hesitate to ask. :)
You'll definitely be one of the first I ask.
Once my band has a good quality cover or original song out, I'll make sure to send you the link for your opinion/advice.
Thanks again.
Enjoy your PC.
(I always do enjoy my PC!) :)
There are usb guitar recording dongles that are designed just for this task of amplifying/compressing the spectrum to something the computer can use. Check ebay or other net sites.
If I HAD to plug it straight in because of budget limitations, do you think it would be better to plug it into the amp into my computer, or just straight into my computer?
