Circuit Help: I need help making sure this circuit will work before I build it?
The other day I bought the iCircuit app for my iPad and was fiddling around with it. I was attempting to design a circuit to...I really can't remember. Anyhow, I screwed it up, but in the process, made this (See picture). It says it should turn on and off/sine wave type waveform at 7.34Hz roughly. I wanted to know if, because I screwed up what I was making, if this is just screwing up the physics of the app, or if that is actually the way it would function. I will upload a video of what the app is doing. If this actually works as it shows, well then, best screw up ever! :D
Appreciate the help!
Here is the video of the app as its going, and yes, I have the app set at a different time interval, that is why 7.34Hz waveform looks ridiculously slow, that isn't the problem:
18
answers
Answer it!
Yes. Anytime you combine L (inductance) and C (capacitance), you get some resonance. In fact, you could make one with fewer components. Look up the basic types--colpitts, hartley, clapp, relaxation, etc.
(The challenge in electronic design is often preventing oscillation, not creating it...)
The 2N3906 has no resistor on the base, that's can't be good.
And here does the signal input come in, I imagine that it should be onto the 2N3906?
L
As for signal input and anything else, I have no idea, I am not great at being given a circuit and figuring it out, I am better at thinking about it while I build it, that's why I need the help, I never intended to build this. Mostly, I want to know if I built this, if it truly would produce the waveform shown on the iPad.
Thanks
If it's a few millivolts, that may just be round-off/sampling error in the software...
eye wash.
A
Steve
1) the PNP is all ways On !
even if you add a Resistor, yet the Sadw
Does not warn about destructive base current.
2) with a steady +5V on the inductors , I
Don't see how the LRC is pumped
3) That leaves the NPN be diode to do the ocs ?
A
That's why I pointed the OP to other oscillator circuits. He's just experimenting. He can come up with something better.
Regardless of whether this circuit oscillates in a simulator, I've made plenty of circuits that oscillate--that wouldn't have in the sim. :-)
