Clock radio makes static noise, when put my hand on right rear corner noise stops volume increases.
4
answers
Answer it!
Otherwise, if you see a little black or white wire coming from the back of the radio, find a way to tack this to the wall vertically - the straighter and higher, the better. This is a cheap external FM antenna that is often built into clock radios.
Tune to a stronger station and that should go away.
Or turn the radio a little until the station comes in stronger.
Your hand is acting as a reflector or antenna.
Do you see an, “antenna” on your clock radio? I bet not so the reason is because it’s using the ground of the unit it’s self and when you touch the clock radio, it uses you as an antenna. At lest thats what I think. LOL
