3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Coil gun projectiles?
Will solid discs (think coin-sized) work as coil-gun ammunition?
Or is a hole in the centre absolutely required for the eddy-currents to flow?
Aug 25, 2011. 7:39 AMagent harmsy says:
It would probably go out of the barrel, but a disc isn't the most ideal projectile. Had a little experiment the other day walking down the stair shaft at uni, dropped a couple coins down the middle and watched. The coin flips and flops and generally doesn't hit the bottom. If you put some kind of spin on it then it'd be brilliant, but pointed cylinders fly the best, at least in my coilgun :D Good luck.
Mar 24, 2011. 3:37 PMeneergcam says:
Pretty sure any metal conductor will work, but with a varied effect.
Feb 28, 2011. 2:56 PMJamesRPatrick says:
A solid projectile will work(most DIY projectiles are solid). However, I don't think that a coin would stay upright in a barrel. A bullet shape would work though.
I think electromagnetic accelerators(the ones that can fire non-ferrous projectiles) that use washers for ammunition use a slightly different principle than regular coilguns.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
