Controlling 10 RGB LEDs with three pots(with out a microcontroller)?
hello i was just wondering if it was possible to wire 10 rgb leds together run all the red leads to one pot, the blue to another, and the green to the third, and have all of the leds colors controlled by turning the pots.
Any information would be helpful. I am intending to use this as lighting on my head board in my room. Id be using 5mm UltraBright RGB Tri-color LEDs
Thanks to all who reply.
7
answers
Answer it!
To get around this you use a pot to drive a curent limiting led driver. this instructable does exactly that. It's as simple as you will find.
if you are determined to avoid microcontrollers then a 555 pulse width controller may be a solution - ccts on line.
for an easy microcontroller solution look at http://www.picaxe.com
