loading
Controlling the speed of the ceiling fan?
I have a standard ceiling fan of which the speed can be controlled by pulling the cord. As the slowest of the three speeds is still to fast, I would like somehow to be able to lower the speed. Is there any way of doing this? The fan operates at 220V
Picture of Controlling the speed of the ceiling fan?
presting6 years ago
"Fan Speed controller" is a common item nowadays. They are made by Cooper Wiring and by Lutron (among others). Some models are continuously variable, others have a few preset stops. Models with comination light dimmer switches are also available. I got mine (a simple rotary) at Home Depot, 9.98 plus tax. I also found them online. As others have mentioned, you don't want to use a dimmer switch inteded for lights on a fan. Dimmers only lower the voltage passed through, and could cause the fan motor to stall.
Re-design7 years ago
Most dimmers are NOT to be used on motors. There is a speed control made especially for ceiling fans. Mine has 3 speeds, you can get 5 speeds though. This speed control is installed instead of the wall switch. Set your fan speed on med or slow and then your new switch will give you 3 or 5 settings at or below the speed set by the original switch.
Almost any store that sells ceiling fans will also sell these speed controls. I know the 110V versions are also available over the Internet; I presume 220V equivalents can also be found that way.
Are you sure it's not a 110 fan.
lemonie7 years ago
How about a TRIAC control, these things are fitted to vacuum-cleaners?
L
seandogue7 years ago
I'd consult the mfg first for this application, to ensure that you won't run into problems at lower speeds... I have a late 1980s Casablanca ceiling fan that has a wall-mount (replaces a standard switch unit) electronic switch/fan control that offers 9 speeds...However, I've seen many people hook fans up to dimmers. Measure the current used by the fan at all three speeds. Get a dimmer rated for at least twice as much as it uses fully loaded. Watch the control when powering up at very low speed, as the motor at speed zero is a dead short..
