Convert a 13.2 volt tool to 110 ac?
I've got a Woodzig (a super-mini chainsaw) that no longer takes a charge. It's also no longer made. I'd liker to get out of battery mode altogether.
How hard would it be to convert it to ac? I've emptied a battery pack, so I have a shell with a red wire and a black wire that snaps onto the bottom of the saw.
7
answers
Answer it!
The reason it would be fun to know how much current your tool draws is because current is one of two factors in the equation for power, that is:
P = I *V
You see, if you're going to get serious about going shopping for, or building a DC power supply, it is helpful to know those two numbers: voltage and current-while-loaded. Not all 12 V DC power sources are the same. Some are capable of supplying more current (amperes), and thus more power I*V, than others.
The reason I suggested a car battery, is because this source roughly matches the voltage your tool wants, and because a car battery can supply a lot of current, for some number of minutes...
If you don't have a car, or don't want to mess with the battery on your car, then you should borrow a car from a friend.
Some related 'ibles:
http://www.instructables.com/id/Convert-a-battery-drill-to-wall-power/
http://www.instructables.com/id/Mod-a-cordless-power-tool-battery-to-run-with-wall/
http://www.instructables.com/id/How-to-Make-AC-Powered-Batteries-for-your-DC-Pow/
The search I used find the 'ibles linked above:
http://www.instructables.com/pages/search/search.jsp?replace+tool+battery+ac
You'd be best replacing the motor.
If that sounds impractical, a 110VAC to low voltage DC supply such as a car-battery charger might be a good try.
L
Plug it into mains (110v or 240v AC) and it will output DC up to 10A or more depending on what power supply you buy.
I don't know what current a chain-saw might draw but this powers my air compressor very well.
most power supplies are 12V (close enough) as for getting the exact voltage that might require a little extra wiring (nothing expensive) but I won't go into that right now.
- Tom
Note: the power supply I bought intentionally had similar characteristics to a car battery, but this is potentially cheaper and won't need recharging all the time.
you said that it no longer take3s charge. s3o the battery i3s fx*x*x*d up. it encountered sulphation
