loading
Converting delay to millis.? need help !!!!
* Hi Everyone.
 I am just starting with Arduino uno.
I was wondering if you could help me?
I would like to replace "delay" with  "millis()"
  My Project Out Line.
*  "LED Light" On/Off with delay using "Relay Module" and "Bluetooth Hc-05"
*   working fine with "delay sketch" but I cannot schedule 2 Events at the same time.
*   So remodifing sketch using "Millis"
*   original sketch link: https://docs.google.com/document/d/1GpPH8rG_bR2Vp282nv7kyB1Zwa0shtpDcAj3-_txnxE/pub
  what will happen is when I send a command A to H the relay will be switched on and if I send a to h the relay will be switched off.
  I have programmed it so that
  A is relay one on (latched)
  B is relay two on (latched)
  C is relay one on for 30 Minutes
  D is relay two on for 1 Hr
  E is relay one on for 2 Hrs
  F is relay two on for 5 Hrs
  G is relay one on for 1 second, then relay two on then both off
  H will switch relay one on and off for 1000 times
  the relays switch on when the digital pin is grounded. and the relay switches off when the digital pin goes high
  here is the code
// On and Off Times (as int, max=32secs)
const unsigned int onTime = 1000;
const unsigned int offTime = 500;
// Tracks the last time event fired
unsigned long previousMillis = 0;
// Interval is how long we wait
int interval = onTime;
// Used to track if LED should be on or off
boolean LED2state = true;
char val;         // variable to receive data from the serial port
int ledpin = 2;  // LED connected to pin 2 (on-board LED)
const int LED = 13;
//  ####### Setup #######
void setup()
  pinMode(ledpin = 2, OUTPUT); // pin 2 (on-board LED) as OUTPUT
  pinMode(ledpin = 3, OUTPUT); // pin 3 (on-board LED) as OUTPUT
  Serial.begin(9600);       // start serial communication at 115200bps
  pinMode(LED, OUTPUT);
//  ####### loop #######
void loop()
  if ( Serial.available() )      // if data is available to read
  val = Serial.read();         // read it and store it in 'val'
  //  #####  Simple LED ON/OFF with out Delay #####
  if ( val == 'a' )              // if 'a' was received led 2 is switched off
    digitalWrite(ledpin = 2, HIGH);    // turn Off pin 2
  if ( val == 'A' )              // if 'A' was received led 2 on
    digitalWrite(ledpin = 2, LOW);  // turn ON pin 2
  if ( val == 'b' )              // if 'b' was received led 3 is switched off
    digitalWrite(ledpin = 3, HIGH);    // turn Off pin 3
  if ( val == 'B' )              // if 'B' was received led 3 on
    digitalWrite(ledpin = 3, LOW);  // turn ON pin 3
  } //else (ledpin = 3, LOW)        //set led pin 3 to low state
  // Need Help
  //  #####  Simple LED ON/OFF with Delay using Millis #####
  if ( val == 'C' )              // if 'C' was received led 2 on for 30 Minutes
    // Grab snapshot of current time, this keeps all timing
    // consistent, regardless of how much code is inside the next if-statement
    unsigned long currentMillis = millis();
    // Compare to previous capture to see if enough time has passed
    ((unsigned long)(currentMillis - previousMillis) >= interval); {
      // Change wait interval, based on current LED state
      if (LED2state) {
        // LED is currently on, set time to stay off
        interval = offTime;
      } else {
        // LED is currently off, set time to stay on
        interval = onTime;
      // Toggle the LED's state, Fancy, eh!?
      LED2state = !(LED2state);
      // Save the current time to compare "later"
      previousMillis = currentMillis;
      // wait 30 Minutes
      digitalWrite(ledpin, HIGH);      // turn Off pin 2
//Thanks in advance
//Krish
JRV311 year ago
Try this:
const int LED = 13;
void setup()
void loop()
// Need Help
// digitalWrite(ledpin = 2, LOW); // turn ON pin 2
if((currentMillis - previousMillis) >= interval) {
if (LED2state) {
interval = offTime;
} else {
interval = onTime;
digitalWrite(ledpin = 2, LED2state);
// wait 30 Minutes
// digitalWrite(ledpin, HIGH); // turn Off pin 2
bvamsikr (author)  JRV311 year ago
its working great, thank you so much for sparing your time to helping me in my project,
but for my project I need Led to stay on for at least 1 to 2 Hrs and it should not Toggle (ex: if program light to stay on for 1 hour, after 1 hour it should stay OFF until the next command).
