Cooling of Laptops - It it possible to use copper pipe and heat convection to achieve this??
I have read that using a hot water bottle is an effective way of reducing the temperature. I actually tried this method and it gave me much the same result as the fans. see this site http://digitalcomposting.wordpress.com/2008/04/30/water-cooled-laptop-stand-6/
Has anyone tinkered with the notion of using a sealed copper coiled tubing with water or coolant. That the laptop can sit on via a thin aluminum plate as its base and acting as a heat transference agent then using the natural heat convection en.wikipedia.org/wiki/Heat_transfer to cool the laptop. This is achieved by having one of the sealed ends of the copper tube immersed into cold liquid. The convection would presumably happen due to the heat and cold differences. Your opinions and further Ideas are welcome.
5
answers
Answer it!
Physically cooling the outer casing will do little, as its generally somewhat insulated from the really hot components inside. All you can really do with an intact case is make it easier for the existing cooling system to do its job - which it seems you already have.
Some guy hacked his laptop, what he did is here:
www.instructables.com/id/Adding-extra-cooling-to-your-ibook-g4macbook/
You could use a PC watercooler kit though.
L
