Could a Pug Mill be used to make uniform Earth Bricks suitable for construction?
I've been looking for ways to create Compressed Earth Bricks and thought about using a Pug Mill (commonly used to get air out of clay) with a rectangular extruder to do all the hard work.  Has anyone had experience with these mills?  Am I crazy for thinking this could speed up the process of building with earth?
May 28, 2012. 12:42 AMsteveastrouk says:
I don't see how you would get the isostatic compression that making them individually would give you, so the resulting blocks would tend to fall apart.
Steve
May 28, 2012. 2:37 AMsteveastrouk says:
Don't get me wrong, I like the idea too, but I just have doubts that the resulting block could ever be as dense as a simple pressed block, and I know that earth block strength COMES from that compression.
I'd be "happier" (as if my view mattered.... :-) ) if you extruded your block and THEN stuck it into a form to apply a substantial squish (technical term) to set a final, high compression.
I think you'd still be winning, in terms of labour saved.
May 27, 2012. 9:55 AMKiteman says:
What is the normal method for making earth bricks?
Most earth-built houses I have seen recently have the earth in bags, or poured into hollow forms that stay in place when the house is built.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
