Could i convert an air compressor into a Diesel Engine ??
I've heard its possible to convert a small compressor into a diesel engine ??
could someone post some info on how to do this or point me in any direction ??
4
answers
Answer it!
Websearch how diesels work, and you'll see that they ignite not with a sparkplug, but with the heat obtained by compressing the fuel-air mixture. As with other engines, ignition produces power which then drives the piston back down. Some set of valves is needed to vent off the burnt mixture and introduce more for the next combustion cycle.
Obvious complications are those valves, making the thing strong enough that it doesn't blow up or burn up, and making sure the motor actually completes the cycle rather than being driven back in the opposite direction. Give me a few minutes and I can probably think of others.
Rather than destroy a good pump trying to make a bad engine, I'd suggest keeping the pump and hunting down a used engine.
Ork is correct, a compressor simply won't survive the stresses that are generated by the fuel-air detonations.
