3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Could you make a ghetto mortar out of an iron pipe?
Imagine that you take a four foot long iron pipe and cap one end of it. Near the capped end, you make reasonably sized exhaust holes. Just above said exhaust holes, there would be a few metallic protrusions that would stop a round from sinking to the bottom of the barrel. Aforementioned round shells would be made of smaller, thinner metal and filled with propellants. Means of ignition is still TBA. But if such barrel and rounds were constructed, could it effectively launch rounds long distances?
Jun 12, 2009. 1:15 AMTombini says:
Yes, although I wouldn't recommend using any metal (try PVC or paper based tube) Depends on the type of the propellant, the projectile etc
Jun 14, 2009. 6:53 AMTombini says:
Firstly PVC does work for low pressure cannons (I have used it myself) because the energy released from the reaction (although it is very exothemic) only lasts for a small period of time, this means the tube won't get as hot as many people think. Secondly black powder is the perfect propellant, use somthing that is a low explosive (deflagrates rather than detonates) You could use flash candy (see my instructable), but only as a last resort
Jun 15, 2009. 1:43 AMTombini says:
I'm almost 16 You're shell idea seems valid although I would test it a few times without a shell then with a shell full of sand before you get into the real deal. Instead of using a fuse that requires oxygen just use a sparkler, they are common and easy to obtain. I'm a bit confused about what you're trying to say about you're design... Easiest method; -PVC tube with end cap on one end -Drill a hole in the end cap to be able to insert fuse -Place required amount of propellant in aluminium foil -Put aluminium foil down the tube with the fuse pushed into the foil so it is contacting the propellant -Put projectile into place -Use This is a very simple and rough design but perfect to get your head around some of the concepts Use a tightly fitting projectile as this minimises wasted energy from leaks therefore maximising energy transferrance and distance Safety is a key factor in participating in ANY activity that involves explosives, so if you havn't allready got one consider buying a full face shield, my father works in the country alot and gives me safety gear all the time (I have 4 safety glasses, 2 full face shields and 3 pairs of Dexi Pro gloves)
Jun 16, 2009. 10:53 PMTombini says:
I think we have similar ideas... I have been looking to expand my rocket launcher and make it actualy fire the rocket out using some propellant, this would allow a small increase in exit velocity and would contribute to some decent recoil! I need to ask, what exactly do you want to do with the shell? Do you want it to explode? Be a rocket? Create smoke? I think you should just experiment with inert projectiles to get a general diagnostic of the design. Then once you feel you are adequately prepared, start using rockets and other projectiles.
Jun 17, 2009. 8:22 PMTombini says:
Ahhh, smoke bombs That brings me back to when I sold little ones at school for a $ each (good times) anyway... don't use a casing just use a slug, a while ago when I was tampering with roman candles I made a cannon; It was made of aluminium with an ID of 25mm and a length of 1500mm (yes a meter and a half!) The projectile was a 60 gram lump of Rcandy and the propellant was 10 grams of flash candy. The projectile reached an apogee of around 300meters and because only half of it burned I heard the other side thud into the ground. Trust me it will work.
Jun 19, 2009. 1:00 AMTombini says:
No, I live in Australia and Ive never used black powder.
Our government restricts alot of chemicals -sigh-
I'm not trying to dissuade you from using a casing I'm just trying to point out that it is much easier to work from the ground up, write down the plans you have now and slowly progress onto them.
With the casing, if the black powder takes more than a few seconds to burn out then it will probably melt the PVC. Thats one reason why not to use a casing
The amount of propellant I used looks like this (when confined)
http://www.youtube.com/watch?v=GNzbGgi8WvU
At 25-26 seconds (just after the rocket motor)
Also, give me you're youtube account (if you have one)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
