loading
DC time delay?
Here's the situation-I close a switch completing a circuit,providing DC power to a load(6 volt,0.1 A).But I do not need the load to start functioning as soon as the switch is closed i.e,only after a delay of say..30 seconds.I googled for "Time delay circuits" but the ones I got were either dealing with AC or the transistor -capacitor(Time Constant) based circuits that makes a load function for a preset time after the circuit switch is opened.I think I could achieve this "pre-delay"  with elements such as transistors,resistors,capacitors etc. but I can't figure out how.Please suggest possible circuits that can be used to achieve my purpose.
iceng4 years ago
Here is a very simple After Relay.
Once turned ON the capacitor C begins charging through resistor R
Eventually the capacitor voltage rises high enough to trip the Diac
and turns  ON  the SCR  which  Closes the Relay .
This will stay closed until power is turned OFF !
A
rickharris4 years ago
Use a 555 timer to operate either a relay or a transistor as a switch.
main switch operated the 555 and the end of time operates the relay to turn on the main circuit.
Adarsh_tronix (author)  rickharris4 years ago
I don't have much experience with the 555 but I think u r talking about its astable mode.Could you add a schematic to give me a good idea?Appreciate it.
Nah bro, Monostable.
Adarsh_tronix (author)  mrmerino4 years ago
