3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Projector bulb problem ?
In reading some of the instructables on DIY projector lamp replacements I decided to give it a shot. So I purchased a Proxima Ultralight LX1 off of ebay, and when it arrived it contained no previous bulb, so I purchased a MR16 style 100 watt halogen bulb and installed it (with a seperate power supply). When I started it up and connected it to my laptop it worked fine for about a minute or so (give or take) but then the image went blank (not the bulb but the LCD screens showed blackness) for five seconds, then the image popped up as nothing had ever happened. I have tried everything to prevent this, other computers, killing the ballast (which is quite easy, only one wire to disconnect) different video sources and no dice. But I do know that it has nothing to do with the light bulb because it is on a completley different power supply and is not connected electronically to the projector in any way, there is something wrong with the controls of the unit
Any Help would be appreciated, Thanks
Bwpatton1
Jan 8, 2011. 5:58 AMplanecaptain says:
You have to bypass the bulb detection circuit. You have to do research on your particular model. You can search archives on these sites.www.allinbox.com, or lumenlab (projectors) ,they also now make cnc robots. I was able to use a jumper on a Panasonic to use a halogen. This was eventually replaced with a hid automotive bulb and ballast.
May 30, 2010. 1:07 PMclaudiopolis says:
I believe your problem is related to the fact that any commercial projector has a bulb detection circuit. It's the first step that need to be done when using other bulbs. That circuit waits until the PSU is striking the bulb a few times with a couple hundred volts to turn it on. Then it checks the feedback. It's either a photocell or some voltage detector, anyway, until you won't bypass this circuit, the projector will shut down automatically. Check my instructable for a more detailed explanation. However, each projector has different electronics so it's case by case scenario.
Jan 28, 2010. 2:26 PMlemonie says:
Is the temporary darkness a real problem, or can you live with it?  I doubt the bulb is causing this problem, but it is a used unit.
(Ah divvunt knaa)
L
Jan 31, 2010. 1:08 AMlemonie says:
So it goes black repeatedly? Is this random or at regular intervals?
L
Feb 2, 2010. 3:18 PMlemonie says:
That's screwy, I'll have to think about it.
L
Jan 27, 2010. 7:00 PMframistan says:
I am reading between the lines of what you wrote.  I suspect you made a BEST GUESS as to the bulb to buy.  Am i wrong?  You must research the model number of the equipment.... and be SURE to order the proper replacement bulb.  I am not an EXPERT on this... but i have SOME experience.  I wanted to AVOID paying the 125 dollars for the EXACT replacement bulb in my 60 inch hitachi TV.  So i bought a ten dollar bulb from the hardware store... and spent 45 dollars and many hours of work modifying my TV's projection bulb socket.  It WORKED... but not as bright... and I worried about damaging the electronics of the TV.  So finally I ordered theEXACT bulb, and now the TV works perfectly.  I learned my lesson the hard way.  Do a search on google for your model number and find the exact bulb replacement is my suggestion.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
