DIY mechanical Iris ?
Hello all,
Im going to try to make a mechanical iris out of wood and make it the lid to a box type thing, as seen here http://www.thingiverse.com/thing:4551, but i need a diagram or outline of what one of the shutter pieces looks like, I would like there to be only 5 shutter pieces, and i would like it if they didnt over lap each other, but any diagram of one might work, PLEASE HELP if you can. Thanks!
~captain molo
8
answers
Answer it!
Inscribe a circle with a compass on piece of paper the size that you want it.
Measure 5 points on the circle, 120 degrees apart
Using your compass, from the center of the circle inscribe an arc through each point on the circle.
That give you the basic layout of each piece
Add a tab to each for your actuating arm to attach and a hole at the pivot point of each lens.
1. open it in a image viewer in your computer
2. make a zoom until you have the correct size
3. tape a sheet of thin paper over the display
(you must at this time be able to see the image over the paper sheet)
4. start drawing over the paper, not pressing too much
5. add the parts you can't see
you can also draw the entire circle with this system (just think).
or any piece you need. also you can mix divided images to get an entire piece.
Chekespeare from Monterrey, MX.
Draw a circle. Keeping the compass at exactly the same setting, put the compass point on the circle line you just drew. Then use the compass to draw two little lines where the pencil crosses over the circle. Place the compass on one of the crosses that you have just drawn and repeat. Each cross is about 1/6th of a turn around the circle. Once you have all six crosses put the compass point on each cross and draw an arc from the centre point to the circles edge, giving you the correct arcs at 1/6th spacing without measuring a single angle.
