Dead CPU?
I have an HP dv7 1130us laptop that recently quit working. One day it worked, and when I went to turn it on the next day it gave me a black screen and the light by the caps lock button blinked every few seconds. Looking on the hp support page for my computer I found that the blink code meant that the CPU had a problem (see here). I tried taking the CPU out and plugging it back in. Then I bought a CPU from ebay (it is brand new) and put it in. Same problem.
When I turn it on the fan comes on strongly then cuts to a lower rpm abruptly. No light comes from the screen. As I said the caps lock and num lock lights flash once every 2 or 3 seconds. The light by the power plug stays on solid. I am not sure how it could matter but I should also mention that we got a new wifi router the day before this happened. There is other helpfull information here.
Do you have any ideas about what might be the problem?
May 28, 2012. 9:08 AMVyger says:
I have a notebook that a customer gave me to look at that is doing almost the same thing. I think its the motherboard that is semi dead. It still gets power and the power circuits work, which is why the fans work (probably still has power to the USB also) but a component on the main board is dead. The screen gets power but never displays anything.
I tried a test card but since the board is inert it doesn't do anything beyond powering on. You can get these things really cheap now and you might get one just for curiosity. The notebook ones connect to the board by removing something like the wireless or bluetooth and plugging them into the slot. You may not find a slot to plug them into on all notebooks.
I think the problem with this one is the BIOS, I think the Chip went bad. It might be the same for yours and there is no real way to replace it that I know of.
May 28, 2012. 2:04 PMlemonie says:
Did you try the memory before buying another CPU?
Did you mess with it in any way at all unusual? (plugging a router into it probably isn't it if it still doesn't work with it unplugged)
L
May 29, 2012. 1:57 PMlemonie says:
Weird, well let us know if you fix it.
L
May 31, 2012. 7:36 PMlemonie says:
Yes, sometimes starting again works best, best wishes with it.
L
May 30, 2012. 3:41 PMemuman4evr says:
If the motherboard has one of those little CR2032 button cells on it try pulling it out then waiting for a little bit then putting it back in. This fixed one of my previously "dead" computers.
May 27, 2012. 4:02 PMfrollard says:
Try unplugging then re-plugging all hardware, could be a simple loose ram chip...if both cpus are acting up, could indicate a few problems with other components (like video card)
May 28, 2012. 5:02 AMfrollard says:
I don't want to say buy another card (particularly if it has integrated video) -- might just be a dead motherboard in that case;
Without the ability to test the components it is really hard to say. How does the computer boot with only one ram stick inserted (if multiple), and/or the other.
May 28, 2012. 1:21 PMRe-design says:
TAke everything off the computer except power supply, vid card, memory, hard drive and cpu. Try to boot. If it boots then your vid card and everything you have on the computer is probably fine. Not add in the rest of the stuff until you find one that causes it not to boot.
Now if it didn't boot then find a replacement vid. card to try.  It if boots now then your orig. vid card is probably bad.
If it didn't boot with the replacement card then replace the original card and try a different power supply, then memory.
You have to isolate the problem to just one item by substituting parts until you find the bad one.
It could be a bad harddrive, cd drive, memory, powersupply, motherboard, and card that is plugged in, etc.  The diagnostic beeps are just a starting point and are often wrong.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
