Direction: Climb vs Conventional?
I am new to CNC routers and Fusion 360 so I'm looking for some guidance. The following summarizes what I've experienced and what I've seen in the Lessons you have provided.
For woodworking I was under the impression that conventional direction should be used whenever possible. This was for safety reasons, handhelds getting away from you or wood kickback on a router tables. Lesson 9 describes Direction in detail and states, in his opinion, climb has no advantage when working with wood. For the projects that I have tried the simulated time estimates varied a lot. i.e. 1:44 (climb) vs 32 (conventional). So if this is true that there is no advantage with wood and it results in a heavier load on the CNC and longer runtimes should I stick with conventional direction?
Thanks in advance!
JON-A-TRON4 months ago
With the kind of work I've done, I haven't noticed a significant difference in the results I get with climb vs. conventional. I would imagine the directions might affect tear-out, depending on cutting in relation to the grain.
If you're getting big differences in the duration of the job with climb vs. conventional, it's probably a good idea to check that against other jobs. The geometry is probably a big factor. Here's a good forum discussion on the topic that might be useful: http://forum.seemecnc.com/viewtopic.php?t=8140
