loading
Do leds contain toxic material such as arsenic or lead?
I heard something about LED light bulbs containing lead or arsenic. Does this apply to LEDs like the small kind?
Well, the short answer is "yes", or "often yes".
More specifically, the LED junction itself often, but not always, includes a semiconductor called gallium arsenide (GaAs) which obviously contains arsenic.
https://en.wikipedia.org/wiki/Light-emitting_diode
However in any size LED, the semiconductor part is very small. Moreover, it is entombed in plastic, so it is going to be very difficult for the arsenic atoms to escape, for to poison any people, or plants.
Regarding lead, Pb, there is often lead in the solder alloy used to connect the LED to the circuit drives it. For example if you build circuits yourself, with solder and a soldering iron, the solder you're using is likely Sn60Pb40, which is an alloy of 60 percent tin and 40 percent lead, by weight. I think that alloy is the most commonly solder, for soldering electrical things.
https://en.wikipedia.org/wiki/Solder#Solder_alloys
Anyway, if you're worried about poisoning yourself by working with a soldering iron, don't be, because it doesn't seem to poison people that way.
If you're worried about poisoning the environment with your broken electronic junk, which contains circuit boards, with solder on them, then maybe you should give some thought to how you dispose of these things.
For example, probably the absolute worst thing you could do with an old computer is toss it into a nearby river, so the solder is continuously surrounded by water, and depending on pH, leaching into the water slowly or quickly.
It would be be better if you dropped it off with a recycler who specifically accepts this kind of waste, called "e-waste".
It would be better still if you could donate it to a local makerspace, or hackerspace, because then some of its parts might get re-used.
Another possibility is you could just never throw away broken electronics, maybe with the intention of using the parts yourself, or making it into an art project, or whatever. Although with that approach it is just a matter of time before your house fills up with broken electronic junk.
For more on this topic, see:
https://en.wikipedia.org/wiki/Electronic_waste
https://en.wikipedia.org/wiki/Computer_recycling
By the same token, Salt contains highly inflammable Sodium and the toxic gas chlorine. The important thing is how these elements are bonded together.
+1
And we cannot live without a little salt which are both poison to my body.
MarS10 (author)  Jack A Lopez1 year ago
thank you very much jack a lopez.?
Vyger1 year ago
Compact florescent bulbs contain far more in the way of toxic stuff and since all it needs to be released is the glass being broken an LED light is much better in comparison.
rickharris1 year ago
http://www.tcpi.com/_CE/pagecontent/Documents/TCPL...
If your not happy to read the safety sheet - Short answer is NO - Longer answer see image
