3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Do stitches HAVE to disappear when felting wool sweaters? My felted sweaters have shrunk by >50% & I still see stitches
Jan 25, 2012. 6:35 PMcanucksgirl says:
From what I understand, its the quality of the felting wool that you used. Some are better than others and the stitches will disappear, whereas with some, after repeated washings the stitches are still visible. Unfortunately there isn't anything that I know of that you can do to change this. - I hope that helps.
Jan 26, 2012. 4:30 PMcanucksgirl says:
As I have learned, once a wool sweater is felted, it will not unravel if cut. I would hate to think that there is an exception to the rule, so I would try and cut a small inconspicuous area to see what happens before committing to any major cutting. Here's a "sample" guide of images I found online and laid out for you to demonstrate what felting looks like over the course of several wash cycles. Since I don't know what your material looks like (or its full composition), its difficult to say if we're discussing "apples to oranges"... Maybe the "visible stitching" isn't abnormal at all. Also, I don't know your knowledge of felting. There are many people who think the process of felting occurs from the water temperature and will put their wool under a gentle cycle, when agitation is the real creator of felting. The other major factor in the success of felting comes from the original stitches. If the sweater was tightly knitted or crocheted, there isn't much room for the fibers to bond and felt. If the stitching was done with larger needles, there is more room for the felting process to occur.
Anyway, take a look at the images and let me know what you think.
Jan 27, 2012. 2:56 PMcanucksgirl says:
You're welcome. If you can... upload a photo of where you're at after your next wash cycle.
Jan 26, 2012. 4:31 PMcanucksgirl says:
Right click image and open in a new window for a larger view (the website downsizes images....)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
