3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Do these connectors have a name?
Does anyone know the name of these electrical connection things. Used instead of soldering something together if it needs to be taken apart. They are screwed onto a bolt with a nut. the bolt passing the current to the connector which is attached to a wire.
Nov 28, 2011. 7:41 PMcaarntedd says:
We call it a non-insulated crimp lug. It has no electrical insulation around the crimp because it is made for higher than normal temperatures. Also for this reason it is likely made from a harder material than the usual tinned copper. The size will be determined by the diameter or cross sectional area of the wire it is made to fit on, and the size of the ring.
Mar 25, 2012. 11:23 AMsaastamo says:
In nordic countries they are called ABIKO-connectors. The name comes after firm Abiko, which makes the connectors and quality crimp tools. They have internet site at http://www.abiko.com/
Nov 29, 2011. 8:24 AMKiteman says:
The connector in the first image is called Simon, and those in the other pictures are called Maria and James.
Dec 16, 2011. 1:00 PMListysDad says:
Damn. She told Me her name was Susan...
Jan 4, 2012. 5:13 PMrrrmanion says:
lies! the names are Simon, Martin and James! they lied about they're identity
Dec 2, 2011. 2:20 PMJayefuu says:
Dec 30, 2011. 10:41 AMathos76 says:
Its an uninsulated crimp style ring terminal. But the crimp style looks like a D-sub crimper...
Dec 5, 2011. 11:33 AMhighvoltageguy says:
ring terminal a crimp one.
Nov 28, 2011. 4:55 PMsteveastrouk says:
uninsulated RIng crimp terminals
Nov 28, 2011. 4:27 PMBurf says:
They're called 'solderless terminals'
Nov 28, 2011. 4:11 PMLargeMouthBass says:
"Ring Terminal"
Nov 28, 2011. 3:46 PMThermionic says:
Everything has a name. The fun part is trying to google a part using a visual description.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
