Does Increased resistor wattage effect peak amperage output?
Hello, I am in the process of building a 900W+ (60v ~14a) RC EDM generator. I am using a heavily modified hairdryer heating coil at 4 Ohms resistance at about 1200 watts. According to my calculations (derate transformer output wattage 20% in order to obtain minimum wattage required), I needed a minimum of 720 watts of dissipation on the resistor. Would it be okay to use a higher wattage resistor without any amperage drop on the circuit while it is operating?
Not sure if 3.2 microhenries (I remeasured it) would be enough to not cause any disturbance or decrease in performance in the circuit. Just curious why this would need to be low inductance...
Plain wire wound resistors are also coils of resistive material on a ceramic tube. And coils become an inductor when current flows through them. That is why resistors can be inductive.
IF you wind the resistive material in such a way so that current flow in one direction is matched by current flow in the opposite there is almost no inductance.
The picture below demonstrates one way to make a non-inductive resistor.
Thats what I was thinking, a bifiliar-style layout for the resistive element to cancel out the inductance. Not sure if 6.5 microhenries on the resistive element would be enough to interfere with the generator's operation. Thanks for the constructive input though!
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
You can increase the wattage ( a bigger sized component )
as much as you want to.
The beneficial affect is a bigger wattage runs cooler because of
the surface area and also you won't burn your hand.
A
