Does anyone know how to bend a polystyrene sheet?
Added on May 4th: just to be sure, I'm talking about EPS (expanded polystyrene). The white isolation panels.
26
answers
Answer it!
L
You'll find it easier than a hair-dryer I think.
L
L
I'll let you know.
When I was talking about polystyrene, I was talking about EPS (expanded polystyrene, you know the isolation panels). Where you aware of this, because something tells me we were talking about different things. Are we?
Cut it and glue it.
L
TWO cm thick ? You'll struggle there with a traditional bender then. I think you will have to look at ovens instead, something bigger than domestic.
Can't you just weld the pieces together with solvents ?
Steve
Welding, mm..., maybe, although it's going to be part of a sandwich panel.
Polystyrene has a low melt point so you've got to go slow and easy.
I have heard that dunking the sheets in boiling water is a good way to soften them, but that was for sheets much thinner than 1cm.
I quickly tried emtying boiling water of a kettle onto the sheet, but no real effect. Maybe I was to hurried.
A grill would suggest it does an area, no, the "bender" is usually a long, nichrome wire, which is heated by electricity. there is a long slit in a fireproof sheet, and the hot wire beneath. You put your bend line over the slit, and turn on the heat. Too much, and the plastic burns before it is hot through.
Steve
