I want to dual boot the FEL fedora distro and ubuntu 10.10 on my laptop which seems very capable of supporting both separately, but not yet together. I want to know if its possible to have them dual boot or if I need a different version of one or both for it to be compatible.
You can install any version , any OS as dual, triple or any boot.
Remember that Install Linux after windows as windows' boot loader don't recognize Linux.........or you have to recover boot-loader if win is installed after Linux.
Get any fedora and Ubuntu version.
install one of it .
then go for setting other.
remember swap space can be shared so only one will be required.
Another approach is to install one, install one of the "virtual machine" packages into it, and run the other inside the VM. Which has the advantage of letting you use both simultaneously, and the disadvantage that whichever one runs in the VM is going to be somewhat slower that it would be otherwise.
(Currently I dual-boot RHEL and WinXP, but I'm planning on moving WinXP into a VM.)
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
I did it with Sabayon, XP, Fedora all three.
install one of it .
install both OS on different partitions.
http://www.fedoraforum.org/forum/showthread.php?t=166818
