Earth Ground?
I understand that the Earth can act as a giant capacitor, conductor, etc. What I don't understand is why. For instance, why would ac power from the hot wire dissipate into the ground? (and, for that matter, will power from the neutral wire not do so? If so, why?)
9
answers
Answer it!
At the other end, at the generating station, the generating equipment is also grounded and if a hot wire touches ground it completes the circuit and current flows.
When lightning hits powerlines, it can flow on all 3 lines... hot, neutral, and ground. Hopefully most will flow to ground harmlessly and not cause damage to the home or people inside. However a direct strike from lightning is impossible to fully protect yourself from its effects. Because EVERYONES home is grounded and many poles are grounded.... the effects are usually localized and not throughout whole neighborhoods when lightning strikes.
Here is a little factoid for you to think about : If a spark coil transformer can make a ONE INCH electric spark jump from its terminals... that is about TEN THOUSAND VOLTS. A "two-inch" spark is TWENTY thousand volts.....
Now calculate the voltage of a lightning strike which is 700 feet long.
When you calculate this voltage, you will no longer stand under a tree during a thunderstorm and will be AFRAID to carry an umbrella in a thunderstorm.
(its like holding a LIGHTNING ROD just TEMPTING the lightning to come down and hit you!!!
If you've ever seen a 'downed' electric line, you probably saw all kinds of sparks because when the hot wire comes in contact with the earth a short-circuit will occur causing a large spark that can potentially burn out wiring. It can also kill a human.
The neutral wire is connected to the earth ground. Why? Because it's ubiquitous, and it's the grounding "system" for the natural world. It's an easily attainable reference.
A fixed voltage potential exists between "Hot" and "Neutral." Once the "Neutral" is connected to the earth ground, then there will be some current flow in a connection between "Hot" and earth--the earth-referenced "Neutral" is what's holding the "Hot" voltage at a fixed reference apart from earth.
But you can create your own separate reference for the "Hot" wire, if it's a closed system and NOT connected to the earth at any point. Within that system, HOT can be the ground reference...
L
The "giant capacitor" analogy is not bad. The AC line is alternately pushing electrons through the wire and out to the ground, then (as the voltage reverses) pulling the electrons back through the wire and drawing them out of the ground. Given a good enough earth connection, that's sufficient to provide the current flow you need to power your lights and other devices.
You aren't dissipating "power" -- power is watts, and watts are used only when work is done. There's a tiny bit of power being lost to resistance in the circuit (and in the earth), but it's normally negligible compared to what's being used by the actual device you've plugged in. A perfect non-resistive load would actually draw no power -- and do nothing useful.
