Electric Arc Furnace?
I'm trying to make a furnace that can melt metal.
I've done a lot of thinking on it, and I decided that I'm going to make an Electric arc furnace for a multitude of reasons.
I plan to use an arc welder as the power supply, with two carbon rods as the electrodes, creating an arc just above the crucible to melt the metal. I was wondering if anyone has done anything like this before?
I plan to have the furnace body made out of firebrick and refractory cement. Would this pose any problems?
Also, how much strain does this put on a welder? Will it need to be shut off after a while due to overheating, or can it sustain it's own?
Finally, How much power does a typical arc welder use? (in terms of watts)
quader42 years ago
If you're interested in building an arc furnace, here's one the King of Random made:
My suggestion would be to talk to the experts. Perhaps the furnace company in Edmonton can help you?
liamm13205 years ago
I don't think it's a bad idea. We've been wanting to get some better furnaces in Edmonton. Does anyone know where to get them, I'd love some help, thanks.
jessesToons5 years ago
Thank for for sharing all of your comments. I have been looking for better ways to deal with my furnaces in Edmonton. I'm feeling more and more confident with it the more time I spend researching it. Thank you guys, wish me luck!
I really had no ideas that a furnace could even do something this powerful. We are investing in a coleman electric furnace and my husband would love if he could do stuff like this with it. Next thing I know, he'll be trying it out!
lemonie6 years ago
I think that arc-furnaces operate at higher voltage than arc-welders.
You need variable height control on your electrodes and are probably best on a 30A mains supply min.
L
tylervitale (author)  lemonie6 years ago
I always thought the voltage didn't matter all that much: as long as you can produce a good hot arc you should be good, right?
I'm not talking about an arc furnace that passes electricity into the metal to be melted, I'm talking about having the arc be from electrode to electrode just above the metal.
Nah, even an arc has a voltage across it. The power IN the arc is still represented by I x V.
An arc furnace strikes the arc ON the metal to be melted, and is carefully adjusted so that the arc continues to strike on the metal.
Steve
I would have said that (but I had to go to work), thanks.
L
A typical "domestic" buzzbox welder here is ~3kW. And most domestic welders ARE NOT continuously rated - they're usually <<50% duty at full output - 5 mins on, 5 mins off at a minimum. Not really ideal for a smelter. Melting metals takes a lot of power. Arc furnaces are used in steel making - look at things like the electro-slag process for example.
tylervitale (author)  steveastrouk6 years ago
well, maybe that could be ok for me...
I don't want to melt anything like tungsten or anything ridiculous like that. I just want to melt copper and aluminum, maybe steel or iron if I could. so with such a hot arc, I wouldn't need to have it on for that long.
Then again, you're definitely right about their power consumption.
I read somewhere about a guy who worked at a power plant, monitoring the meters and what not. He said that they had a large arc furnace nearby, and he could tell when the thing was switched on down at the station just from the sheer amount of power it drew!
