Elmers Glue substitute?
Hi, I have discovered a recipe for Kiddies Slime and it uses Elmers Glue. I have never seen it here. Can anyone advise what I can use as a substitute?
PVA wood glue.
+1 - and a lot cheaper (at least in the UK)
Aribliss12523 days ago
Odettev1 (author) 2 years ago
Thank you all! You are awesome!
in case you are still struggling, bostik white glue
You're welcome
lukeutley_610 months ago
What is a good substitute for Elmers Glue?
rickharris2 years ago
Your looking for any glue that says PVA on it. Essentially these are designed for Paper and wood gluing. You may also find PVA at a builders supplies - it is used to make plaster and cement more tacky.
Personally I buy a gallon jug of generic PVA glue it works fine with borax. Don't use too much or it goes very stiff.
Thank you!!
kelseymh2 years ago
First, you don't define "here," so you're pretty much on your own. Elmer's is a white glue; go to your local hardware store and ask.
Odettev1 (author)  kelseymh2 years ago
Here as in Pretoria, South Africa. Thank you. Will do.
white Wood glue
I've tried making 'Silly Putty' (same type of recipe and ingredients than Slime) with White Ponal Wood Glue, but it didn't work at all. Result was a hard rubbery substance, not putty. I will try out other types of white glue. I've researched a bit on substitutes for Elmer's glue in South Africa, but no luck yet (other than white PVA glue). Would LOVE it if someone found a brand which works well with Borax (it's apparently the PVA and Borax which reacts to make the polymer)
