Film holders are not recognized - Nikon Coolscan 9000 ED
Nikon Coolscan 9000 ED I've been using for 6 years nearly every day now refuses to recognize the film holder._________It says, "No film holder detected. Try to clean the square holes at the front side of the film holder and if this doesn't work, try another holder." _____________ I tried all: cleaned all holders, opened the scanner and cleaned it from dust; restarted the computer; turned the scanner off/on/off/on with 5 min intervals. Nothing helped. ______ Then I tried another program - Viewscan. It also said, "Insert the film holder" while it was already inserted.______   Who knows what might it mean? That the scanner grew too old?
Picture of Film holders are not recognized - Nikon Coolscan 9000 ED
NachoMahma7 years ago
.  That sounds to me like it uses light beams (maybe not visible) shining on photodetectors. Check that area closely for dirt. If there are any connectors on the wires going to the source(s)/detector(s), gently unplug and re-insert.
.  Search the web for replacement parts, if needed.
+1
nicelly5 years ago
On a single from the hands, what ‘Stated in Italy’ will be embossed. You’ll find, the maker ought to be printed in small case above the two lenses. You will be thinking: If just about everything advertising is targeted directly within my customers, if it relates to content tightly relevant to my site along with the services Presented, couldn’t I be sending my clients directly to the hands of my competitors? They could be Google advertisers! Customers are tough together with you would be focused on directing your clients to services given by the competitors. rayban frogskins white. That’s the reason with AdSense, you control which ads display on the blog. ray ban 2140
Nacho has it nailed.
What I'll add its that the "light beams" are usually infra-red, which you can't see BUT your mobile phone camera can. Look at the machine with the camera and see if you can see the lights. You may even need to take the covers off.
Steve
