Flip flops - paint is rubbing off - type of sealant to use?
I bought a pair of flip flops the other day and the paint is already rubbing off where I put the most weight on my feet. I was wondering- is there was any type of sealant I could use to help prevent the rest of the design from rubbing off? It's ok if I'd have to reapply it every once in a while.
Thanks in advance. :)
Jun 14, 2012. 12:52 AMcanucksgirl says:
Buy yourself a spray can of "3M FoamFast 74 Spray Adhesive" (available online, at most hardware stores and craft stores like Michaels). It's meant to bond a variety of foams (like latex), and remain flexible. In your case, just spray the area you want to seal, and allow enough time for the adhesive to cure. It should create a stronger bond and hopefully stop the printing from rubbing off. Over time you will likely have to reapply, but a single spray can will last quite a while.
Jun 12, 2012. 5:03 PMBurf says:
Cover the painted surface with clear vinyl, contact shelf paper.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
