Fooling the robot by putting a very long question header instead of my original three words that I put up two days ago?
I read somewhere?? that to put fridge magnet on the side of a fridge causes it to use more power. (Magnets are OK on the front).
Is this true? If it is.....; why?
Jan 31, 2010. 5:00 AMNachoMahma says:
.  No. Even if you put the magnet on the compressor housing, it would have no effect.
1) The magnet is very weak compared to the field(s) of a 110/220VAC motor.
2) As Re-design points out, the magnetic field of the magnet will be "absorbed" (redirected) by the steel of the case.
Feb 1, 2010. 5:26 AMRavingMadStudios says:
Wow, an urban myth that has never appeared on Snopes.com. That's pretty impressive.
Jan 31, 2010. 3:15 AMRe-design says:
If the magnet sticks to the side of the ref. the magnetic flux gets absorbed by the steel.  Very little goes thru the steel.
Very few of the warnings that you get in email are actually true. But you did the right thing by asking for other opinions.
The robot has a filter that filters out questions that are less than 5 words long and they have to be looked at by a human which may take 48 hours or more.
Jan 31, 2010. 11:19 AMorksecurity says:
Myth. Wherever you read it, stop reading that.
Jan 31, 2010. 2:13 AMSlowpoke says:
The answer is no. It is not true at all.
For a fridge magnet to effect the operation of a standard refrigerator is impossible, unless it is placed as to prevent the door from fully closing or sealing. Also keep in mind that the fridge's door seals are usually magnetic as well.
Jan 31, 2010. 2:03 AMKiteman says:
I also read that there was this magic ring...
Jan 31, 2010. 1:16 AMlemonie says:
What?
Where did you read that?
No it's not true.
L
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
