3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Linkage for Linear Motion from Servo.
This was originally going to be a question on mechanical advantage and tinsnips but I've realised the answer during typing the question. So, my follow-up question is . . .
I'm looking to extend the throw of a servo and convert this to a roughly linear motion but still keep the whole mechanism compact.  I'd like around a 4 to1 gearing (with corresponding loss of force, of course).  Is there a simple linkage I should be looking at to get this?
Sep 10, 2011. 1:15 PMKiteman says:
There is a fairly comprehensive set of mechanical linkages on Rob Ives' website.
I think you're probably looking at some sort of crank mechanism.  If you join Rob's site, you can download a model of a crank for free here.  If you don't join, the model costs £2.50 to download.
Sep 10, 2011. 2:19 PMrickharris says:
Your requirement for linear motion is ambiguous. needs more clarification.
For example this does what you want.
Sep 11, 2011. 12:50 AMrickharris says:
This is slightly more compact using a cam and gives a return motion.
Sep 11, 2011. 12:38 AMrickharris says:
Yep that's a version of a scotch yoke mechanism. will work although you need to attach the follower with another slot/pin to the upright to get reverse motion - or use a spring.
Sep 10, 2011. 1:17 PMiceng says:
Rack and pinion comes to mind. . . . . . . .  A
Sep 10, 2011. 2:51 PMsteveastrouk says:
Err.. Aren't servos postionable ?
Sep 10, 2011. 1:11 PMsteveastrouk says:
How about a "Lazy tong" action ?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
