Germinating Apple Seeds?
16
answers
Answer it!
Get a small 3 - 4" pot with holes in the bottom. Put your soil mix in it and water it. You want the soil level to be about an inch and a half from the rim after watering. Take your little sprout and gently set it on top of the moist soil mix with the sprout pointing upwards. Gently add dry soil around and on top of the seed part (not the sprout). Using a clean spray bottle with water, mist the dry soil until moist. Set in a well lit (not direct sun), area. Mist it every other day for about a week. Then water it only when the top inch of soil begins to dry out. THIS
Some plant need a period of cold to germinate properly, as described in this article.
Even if the apples are poor, I have seen apple trees with several varieties of apples and even pears all grafted on to the mother rootstock.
BUT Genetics being what they are there is a chance.
Commercially Apples are reproduced by grafting.
It's a pretty tree although the apples it may eventually grow will probably be gross.
If you don't have good luck with the apple tree, in the fall find a live oak tree and pick up a hand full of acorns. These sprout very easily using the paper towel method or just pushing half way down into potting soil and keeping it moist.
