3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Glider Part That Makes Gliders Glide?
From the title, I'm sure you can tell that I'm absolutely ignorant about what this part is or how to replace it.  Basically, I have a few gliders with broken bits that are supposed to make the gliders glide.  And because I have no idea what this part is, I've taken a few pictures.
I'm wanting to fix these parts, but I don't know the name of the part and, consequently, where to find them.  Brah!!!!
Oct 18, 2010. 12:47 PMBurf says:
Okay, now I understand what it is you are asking about, I think I may be able to help you. I built a porch glider about 15 years ago and with the exception of some periodic maintenance, has been trouble free.
Rather than the expensive setup you linked to, here is a drawing of what I used and it works perfectly and cost in the neighborhood of a $1.50 per.
Oct 18, 2010. 6:58 AMNachoMahma says:
This patent for a glider seat (PDF) calls them "braces" (items #42 and 43 in the drawings).
Oct 18, 2010. 12:15 PMseandogue says:
Strange. you're right, but a brace is for bracing...odd...hehe/she invented it, and he/she got the cash ;-)
Still a linkage in my book.
Oct 18, 2010. 8:19 PMNachoMahma says:
.  Yeah. Brace is not the name I would have picked. How about "flying link"? Or maybe "parallel link". Possibly even "frame/seat connector". But not a brace.
.  Apparently, that wasn't the part in question, so it doesn't really matter. :)
Oct 19, 2010. 12:02 PMseandogue says:
Ah...so I see.
Oct 18, 2010. 6:34 AMorksecurity says:
For wood gliders, these pivots are available from many woodworking stores -- I know Rockler has them, for example.
Metal... I don't know.
Oct 18, 2010. 3:24 PMRe-design says:
I guess we should'a looked at all of your photos. I was trying to fix the wrong part.
Oct 18, 2010. 11:13 AMorksecurity says:
Looks like it.
Oct 18, 2010. 12:14 PMseandogue says:
+1
Oct 18, 2010. 9:07 AMpaganwonder says:
I agree with RedneckEngineer- you are probably best off fabricating your own parts. Replacements are impossible to find for purchase plus I see from one of your pictures that you are going to have to do some "kludging" to overcome the torn aluminum around the original holes. An idea for reinforcing the torn holes- bend fender washers to fit closely around the tubing (I use steel pipe and a vice as a form) and then J-B Weld them using a bolt and nut to position and clamp washers.
Oct 18, 2010. 8:04 AMRe-design says:
Swing arm. I'd still make my own replacements but the idea of checking Rockler's is worth a try.
Oct 18, 2010. 5:28 AMRedneckEngineer says:
We always called them rocker arms. Good luck finding replacements to buy, I would just make my own and bolt them on.
Oct 18, 2010. 5:08 AMseandogue says:
I'd say "cam" but that's not quite right. Linkage would be the generic term.
I think redesign has the right idea. They're just strips of aluminum. simply cut new ones using the old ones as guides., drill the holes, and assemble.
You might want to check out McMaster for new fasteners. They sell in small qty so no need for a $25 order to get a few pieces.
Oct 17, 2010. 9:37 PMkelseymh says:
Curses! You posted too much description and too many pictures for my first answer...
"Wings."
Oct 17, 2010. 8:19 PMRe-design says:
I don't know exactly what to call them either, but I'll bet you can't just go some where and buy them off the shelf. If they're broken you're probably going to have to make new ones. They are made out of aluminum so it'll be super easy.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
