Basically, i just think about making my own kinda glitter stick - sumthin like this, but bigger: http://www.geburtstagsfee.de/glitzerzauberstab-mit-fliessendem-glitzer-ca-30cm-p-9878-15.html - i guess, it wont be too diffy to find a glitter-vendor, but what kind of oil do i have to use? Any suggestions
It's not oil, it's water. The different colors are achieved with transparent colored inserts or different colored cells that are placed one on top of the other inside the clear plastic tube of the main stick.
There are some that have mineral oil in them to have a slow-globby flow to the innards.
@author, honestly just buy them. The plastic tube (acrylic or polycarbonate) will be more expensive than buying all the components yourself. If you don't mind to spend more, then go ahead, make your own.
ok, to be honest: As a tinkerer, i'm a bit with a bunch of jugglers in Berlin (most of my instructables were such dedicated projects) and i'm often thinkin bout howto make sum tools and i thought bout makin a contact staff using this instructable http://www.instructables.com/id/Building-a-Lightsaber/ - he's using these led-stars and i thought bout mounting them the same way that guy did on his lightsabers and instead of a pvc tube, i'd add sum container of this glitter stuff. That way massive light would pour of this sparkling stuff. And that's why i don't want to by a single glitter staff to absorb all this light.
Bio:i'm 32. With 23, i started with a stage in taylorship, did sum time-work, changed to saddlery, now, while still doin the saddlery, i'm workin for sum middle-age-discounter. Three years ago, i started ...read more »
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
