3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Got a problem with the Arduino shift out function and a LED array
After looking at this instructable, I wanted to start building my own LED array. I found this Arduino article. I bought the 74HC595N chips and connected everything exactly as the article showed it, and copied the first example program directly into the Arduino. The Arduino is connected through the USB cable to my computer for power.
My problem comes in when I hook the circuit into the 5V on the Arduino. When I hook it up the Arduino shuts itself off. I wasn't sure if it was overloading the Arduino, so I hooked it up to an old, plug in breadboard I have which has a limit of 1.5A. When I hooked up the circuit the breadboard produced a high pitch tone and still nothing happened.
I have checked and rechecked all the connections and jumpers, (even looked at the data sheet for the part) everything seems to check out. The LED's are just simple green LED's, but the resistors I am using are 1k instead of the 220 ohms the article said to use (i had only 1k handy and the LED's still light with a 1k).
Sep 27, 2010. 9:11 AMsteveastrouk says:
Something ain't wired right. It sounds like the breadboard PSU can't cope, so you have a pretty well dead short somewhere.
Sep 27, 2010. 1:01 PMsteveastrouk says:
A close escape.
Sep 26, 2010. 8:48 PMWillard2.0 says:
Check over your circuit with a multimeter and make sure there aren't any tiny shorts anywhere.
Did you test the shift registers on a different circuit?  If not, check out this tutorial and try the first circuit to make sure your 595's aren't duds.
Also, try uploading the code from his other led matrix
I can't get his 6x24 code to work, but the code for the 8x10 does work.  Make sure to change the arduino pins to match the new program.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
