loading
HELP ME ::: want to interface ps/2 mouse using uno to pc
Hi friends,
i am new to arduino board. Trying to make a arduino uno based PS/2 mouse by using ps2dev.h... From the example from that the mouse move diagonally only. how to set that in other direction left,right,top,bottom..
// move the mouse diagonally
    delta_x = 1;
    delta_y = 1;
    write_packet()
Anyone guide me, how to move right or left or up or down...plz help me
#include "ps2dev.h"
PS2dev mouse(3,2); // 2 data 3clock
char buttons[3] = {0,0,0};
int delta_x = 0;
int delta_y = 0;
//we start off not enabled
int enabled =0;
//ack a host command
void ack() {
  while(mouse.write(0xFA));
void write_packet() {
  char overflowx =0;
  char overflowy =0;
  char data[3];
  int x,y;
  if (delta_x > 255) {
    overflowx =1;
    x=255;
  if (delta_x < -255) {
    overflowx = 1;
    x=-255;
  if (delta_y > 255) {
    overflowy =1;
    y=255;
  if (delta_y < -255) {
    overflowy = 1;
    y=-255;
  data[0] = ((overflowy & 1) << 7) |
    ( (overflowx & 1) << 6) |
    ( (((delta_y &0x100)>>8) & 1) << 5) |
    ( ( ((delta_x &0x100)>>8)& 1) << 4) |
    ( ( 1) << 3) |
    ( ( buttons[1] & 1) << 2) |
    ( ( buttons[2] & 1) << 1) |
    ( ( buttons[0] & 1) << 0) ;
  data[1] = delta_x & 0xff;
  data[2] = delta_y & 0xff;
  mouse.write(data[0]);
  mouse.write(data[1]);
  mouse.write(data[2]);
  delta_x = 0;
  delta_y = 0;
int mousecommand(int command) {
  unsigned char val;
  //This implements enough mouse commands to get by, most of them are
  //just acked without really doing anything
  switch (command) {
  case 0xFF: //reset
    ack();
    //the while loop lets us wait for the host to be ready
    while(mouse.write(0xAA)!=0);
    while(mouse.write(0x00)!=0);
    break;
  case 0xFE: //resend
    ack();
    break;
  case 0xF6: //set defaults
    //enter stream mode
    ack();
    break;
  case 0xF5:  //disable data reporting
    //FM
    ack();
    break;
  case 0xF4: //enable data reporting
    //FM
    enabled = 1;
    ack();
    break;
  case 0xF3: //set sample rate
    ack();
    mouse.read(&val); // for now drop the new rate on the floor
    //      Serial.println(val,HEX);
    ack();
    break;
  case 0xF2: //get device id
    ack();
    mouse.write(00);
    break;
  case 0xF0: //set remote mode
    ack();
    break;
  case 0xEE: //set wrap mode
    ack();
    break;
  case 0xEC: //reset wrap mode
    ack();
    break;
  case 0xEB: //read data
    ack();
    write_packet();
    break;
  case 0xEA: //set stream mode
    ack();
    break;
  case 0xE9: //status request
    ack();
    //      send_status();
    break;
  case 0xE8: //set resolution
    ack();
    mouse.read(&val);
    ack();
    break;
  case 0xE7: //set scaling 2:1
    ack();
    break;
  case 0xE6: //set scaling 1:1
    ack();
    break;
int xcenter ;
int ycenter;
int xsum = 0;
int ysum = 0;
void setup() {
  unsigned char val;
  // send the mouse start up
void loop() {
  unsigned char  c;
  if( (digitalRead(3)==LOW) || (digitalRead(2) == LOW)) {
    while(mouse.read(&c)) ;
    mousecommand(c);
if (enabled) {
    delta_x = 1;
    delta_y = 1;
    write_packet()
  delay(50);
maewert5 years ago
I would think that to move left you need to set delta_x to -1 and delta_y to 0.
Right: delta_x to 1, delta_y to 0.
Up: delta_y to -1, delta_x to 0.
Down: delta_y to 1, delta_x to 0.
Best Wishes
hey!
ive been tweaking around with the same code, i have used an accelerometer to control the mouse. i hav been quite succesful in moving the cursor, can you please tell me how the ps2 would differentiate between a single and double click.
regards!
I'm not sure.  I believe the double click is just two clicks in close succession.  I think the operating system sets the time between clicks to determine whether two clicks are deemed a double click or not.
Best wishes
