HOW TO BUILT INVERTER WITHOUT USING TRANSFORMER?
12/220 VOLT INVERTER
Are you wanting to go from 12VDC to 220VAC, or 220VAC to 12VDC?
telgammal (author)  mpilchfamily5 years ago
HI Mpilchfamily
i mean if can be applicable to invert 12vdc to220vac without using transformer by using clipping ccts & dc chopper ccts?
thanks for your time
blessing you,,
If you don't know a lot about electrical engineering then don't attempt to build your own 12VCD to 220VAC Inverter.
You can't get around using a transformer when building an Inverter.
you went so far from my question,,,
deeply I ask some one can use capacitors, votage doubler circuits & chopper techniques to convert from 12vdc to 220vac square wave even for alimit power
,,Is the above cann't absolutily be applicable even for amperage fractions.
Why ?
telgammal (author)  steveastrouk5 years ago
many wise only !!!
