HOW TO MAKE 2 CHANNEL RADIO REMOTE CONTROL SYSTEM WITH THE SIMPLEST CIRCUIT
Hi,
i want to make a 2 channel remote control for my new project that is to control a hydrogen inflated baloon with tow fans to change direction to activate these fans i need a two channel remote control . As i am only 15 i don't have much stuff  and can't buy  coplicated things .
So plese give the cheapest and the simplest way to do it and i would be a small circuit .
Thanks in advance,
UNknown.
Re-design4 years ago
The easiest and cheapest way would be to buy one of the cheap two channel helicopters. THen carefully take the receiver out and install it in your balloon. Now take two small motors and sub them in for those that were used.
You can sometimes find the helicopters for less than $20 and there is NO way you could build a two channel trans/rec for anywhere near that even if you had the thousands of $ of test equipment needed to build a trx/rec unit.
rickharris4 years ago
I assume your keeping the balloon indoors RE-DESIGN is right but just to give you other things to think about try looking here and here
IR control should work well for this application.
