HOW TO MAKE A PCB?
I HAVE BOOK IN WHICH CIRCUITS ARE MADE ON PCB SO I WANT TO KNOW HOW TO MAKE A PCB?
framistan4 years ago
If the circuit is not complex, and if you only want to build
one or 2... then you could use a method that i use a lot. Just
get a piece of blank circuit board. lightly sand the surface to
remove any slight dirt or oxidation from the copper. Then just
use the copper surface as a ground connection for various
components. Also, i use a dremmel tool to grind out a few
spots on the board for interconnecting wires. This method
only works if using larger components, not surface mount
parts. I find this method is a good way to build prototypes
without having to etch circuit boards.
Take a look here, at the right of the page for some ideas.
+1
There are several Instructables under "related" (on your right) for that...
Look up how to etch a PCB.
