HP zd8000 screen has bad connection causing picture to fade to unreadable. hinge movements restores it, can I fix it?
cyberguy918 years ago
It sounds to me like: A) Your LCD needs a new inverter (usually the hottest part of the screen). B) You might not be getting a good ground. Try checking if there is a grounding screw in the computer that is loose. C) If all else fails, you might need to order a new screen. Hope that helps
