Hard drive wiping problems REFRASED
25
answers
Answer it!
The right answer *is* to boot from CD. That can be done even when the disk drive is completely dead. Just bring up the BIOS configuration screen and set the machine to try the CD before it tries the hard drive.
If you can't open the BIOS configuration, why not? If it's password protected and you don't have the password, then (a) you probably have no business doing any of this, but (b) if it really is your machine, a service center may be able to reset that.
Note: If this is an IBM Thinkpad and the hard-disk password has been set to something you don't know... trash the disk and buy a new one. That mechanism is intended to protect business data, and so is moderately serious security. I don't believe there's any way to reset it without knowing the existing password, and I *think* it may have some tamper-resistance as well.
If you need to erase the passwords on the accounts, that's a different question.
. You can reset the BIOS on most computers with a jumper on the mobo or by removing the battery for a while.
I suggested you fit it to another machine - did you try that?
You could download a free disc-partition app', but if your CD doesn't work that's no better than any other CD.
Stick with the original question, asking the same thing a second time isn't going to get you a better answer.
L
Your need is to boot the machine from something other than the drive you want cleaned, and run e.g. a disk-partition application off the other boot device.
If you're not going to take it out of that machine, what can you boot it off?
Floppy?
L
What can you boot it from?
L
Can you boot from a floppy, because you could fairly easily get a DOS disk made up I should think.
L
The problem is that if you want to format the hard drive without using another computer, you must boot your computer into something. It's either boot to a CD, flash drive, or floppy, or remove the hard drive and use another computer - there's no third direction.
Since you specifically demanded no instruction on what to check, I won't go any further than stating that if your BIOS is set to boot from CD as your first device, your drive shows up as operational in BIOS, and the drive doesn't have a dirty/malfunctioning transport, then you should have zero problems booting to an XP or Ubuntu disc. Furthermore, neither disc will care what is on the drive - corrupt or not - so a corrupt installation of XP will not prevent you from booting to the CD, nor will it prevent the computer from reformatting the drive.
From your previous comments, it sounds as if though either the installation discs are damaged and unreadable, or the CD drive optics are malfunctioning.
Finally, I can understand your frustration. I'm a repair technician myself, and my day is nothing but frustration when machines adopt personalities and do things that defy logic. However, you just need to maintain. Inhale deeply through the diaphragm and exhale slowly. Eat a peach. Then ask your question, knowing that people who answer are genuinely trying to help you, not run you around in circles.
When you get answers that are strikingly similar and are not what you expected nor wanted to hear, you must accept that either you didn't phrase the question properly, or that so many answers couldn't agree if they weren't true (I can tell you from experience that tech nerds will quibble over some of the most trivial things, so when they all answer in unison you pretty much have to accept it).
Here's some positive and constructive feedback for you: "just answer the question" and a list of ways not to answer the question is not the best way to inspire people to want to help you solve your problem for free and on their own time.
The computer store will either do the same thing, or take the hard drive and use it inside of one of thier computers to do it.
