Has any or does anybody own or ever seen a syma S107 like this one??
It's not a R3 or R5 and the markings on it are different, they go from left to right, one blank soldering joint then a "B+" (continuity in both) then "F", "B", "UP", "D" then a blank which is the battery- (NEG). It has the numbers JLDZ-17A on the bottom but I googled it and it comes up with zip, not even one. Other than that there are no numbers on it and I can't figure out how to wire it, i've tried a few variations that one would think were obvios but to no avail, I know one of you geniuses out there can help a brother out, lol, Sincerely angpal59
I mean it's marked, "F", "B" and "UP" and "D" which one would assume means front and back motor , and "D" is for down but it doesn't make sense. Isn't "F" front motor and "B" back motor, but that operates up and down, lol, I just don't get it.
Now all you have to do is tell me how to fix the toilet bowl effect? What usually causes that?, I have replaced flybars before and that did it, but other times it didn't I think they're are a few different cause for it.I look at the shaft as it spins and I can't see a wobble so it doesn't look bent. What bums me out is I got it going and it used to be my favorite S107 of all time cause of the way it would hover so still and was just so smooth and now I lost that, I've had this one for the longest, I would have to say it's at least 3 years old.
Well, I finally figured it out, the hard part is figuring out the wires,which is pos and which is neg cause my motors have white and black wires. But now I have the toilet bowl effect which it never had, what causes that with a simple S107? Man oh man, if it's not one thing it's another,lol
Nothing but the front and back and tail motors, thats all, because I had done so many before, I was confident that this one would be no problem, but the markings aren't the usuall ones. Also I tried doing the most common sense of wiring but that didn't work. That's why I need help
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
B = Backward
But Recall ! !
It was Pointed Out to you by me that
"The silk screen dash ring flats on your PCB are all wired to minus yellow"
I don't believe you bothered to engage your mind.........
A
Hope this may be helpful for you..
