Has anyone made bamboo wind turbine blades?
I started a set of simple bamboo wind turbine blades today. I'm using instructions for PVC pipe blades. This involves slicing up a plastic pipe (vinyl chloride is carcinogenic) but large bamboo is similar to a pipe and I've got some so why not try this natural material. If you have done this before, please share some insight :) To my knowledge nobody else has posted about this and all I've found online about bamboo blades is from large scale commercial turbines.
snotty (author) 7 years ago
I'll answer my own question here. It's really easy to make these, really easy!<br /> <br /> The answer is yes and they work fine. These bamboo blades are 4 feet long and span about 2.2 nodes. They spin much more readily than the smaller set I made previously. <br /> <br /> Plus the instructable for these is here: <br /> https://www.instructables.com/id/Wind-Turbine-Blades-from-Bamboo/<br />
I don't know of anyone who has done this beyond a few large-scale startups (who haven't written up much in detail). Best of luck!
snotty (author)  DELETED_GuardianFox8 years ago
Here is the first blade. I wanted it to be longer. Can anyone suggest a way to make longer blades from a 10 cm wide tube?
Asmodeo snotty7 years ago
Yesterday I built 4 PVC blades, and, when finished, I saw a bunch of 3m long and almost 15cm diameter..... Then I realized the same that You : why not bamboo!!!??? I think It will be a lot of overweight, an a lot of work to do them....but...why not bamboo!!!?? I think You can make them as long as the distance between kots....at least, they do so when building fishing rods...It seems that knots are kind of a "failure point" It gives Us some 50....60 cm blades. If knots were not an issue.....perhaps I would risk 1m or 1,20 m long blades.that's not bad!
snotty (author)  snotty8 years ago
Here is the first rough assembly. It spins in front of a fan!
