Heating Ceramics?
Is it safe to heat ceramic bowls and cups and stuff on a hotplate or cooktop? Like plain white ceramic stuff.
BTW: The piece in question is almost certainly stoneware, not porcelain or earthenware.
Sep 27, 2010. 4:05 PMseandogue says:
Pyrex containers will work great in ambient heat, (for instance, in an oven), but don't put one directly on a gas burner. I learned the hard way when still a wee lad and broke my mom's 1qt pyrex measuring cup. She was not pleased. Yes, 45 years later I still remember the event as if yesterday. Not pleased at all.
May 11, 2011. 10:41 AMChicken Spit says:
I had a pyrex mesuring cup that completely exploded when I pulled it out of the oven, so don't let it cool to quickly!
May 12, 2011. 5:53 AMseandogue says:
Although theoretically, that should not have happened to you (unless you dunked them in cold water immediately after removing from the oven) Pyrex or not, I'm not so sure measuring cups should be used in an oven. I have had four pyrex baking dishes for several decades that don't experience that problem, but ever since I broke mom's pyrex measuring cup on the stove I use them for one thing only...measuring. I'd be more than glad to experiment with someone else's cups to find out exactly what the cause and/or limit is, but I think maybe you have it...rapid temp change.
May 12, 2011. 5:49 AMseandogue says:
Yes. But it's designed to be used in high heat.
Sep 26, 2010. 7:42 AMQuercus austrina says:
Way back in the olden days (okay, the '60s and '70s), there used to be many glass and porcelain cooking vessels available. ALL OF THESE used a wire "spacer" that sat on top of the electric "burner" to create a small, but absolutely vital thermal space/cushion to keep the vessel from expanding at far too great a rate on the bottom. This kept the vessel from breaking. I suggest you get some tie wire for a fence or concrete construction for this use. If you have an old wire coat hanger, you can use that as long as you take the coating off. The main thing is that the wire be some sort of UNCOATED steel. Shape the wire in either a star or spiral pattern.
Don't be fooled into trying to use a glass coffee pot, as they are not meant for burner use. Yes, they sit on a burner, but it is a much lower temperature than stovetop burners and they are heated from both the inside and outside when you make coffee.
Qa
Sep 26, 2010. 4:56 AMNachoMahma says:
.  Most porcelain labware can be heated without breaking. Most tableware cannot.
Sep 26, 2010. 1:04 AMlemonie says:
If it's ovenware, designed to take heat you may get away with it. But like rick' and Jack' say, not really a good idea.
L
Sep 26, 2010. 12:27 AMJack A Lopez says:
Rumor has it that fired clay, the stuff most coffee cups are made of,  is kind of a mediocre conductor of heat. For that reason I would guess that you'd have trouble getting heat to flow through the bottom of the cup and into your coffee, or soup, or whatever. It might take a while to heat up.
But you should not let yourself be stifled by convention.  If you want to heat your coffee cup over an open flame, I say do it!  But wear your safety glasses though, because the damned thing might just crack in half and spill your coffee everywhere.  I know that happens when you try to heat stuff in soda-lime glass, like the jar the grape jelly or the salsa came in.  I think it has something to do with uneven heating and different parts of the the structure expanding thermally at different rates.   Anyway the damn thing breaks, and then you realize that just isn't going to work.
Borosilicate glass is another matter.  That stuff is great for cooking, and for chemistry experiments.  You can heat it over an open flame and it won't break.   I've even heard/read rumors of people making homemade boiling flasks from old incandescent lightbulbs.
Anyway, regarding heating your coffee cup, I know "try it and see what happens" might not seem like much of an answer.  I mean you probably could have thought of that by yourself.
Sep 26, 2010. 12:32 AMrickharris says:
uneven heating may well crack your china. So beware. Not recommended
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
