Help, I have a problem with my LED circuit.?
9
answers
Answer it!
L
power supply>>>>
v v
string 1 string 2
v v
each string has its own unique resistor. 10 LEDS in a row will take a minimum of 15-20 volts...you may need shorter strings, especially for blue. Divide your source voltage by the individual voltage of the led to find how many you can fit in a row. i.e. 9 volts with 3 volt leds will require 3 leds to sink the 9 volts, and a small resistor to keep current in check. 2 volt leds will need 4, (to make 8 volts) and a resistor to drop the last volt.
