loading
Help! My Leds wont sync to the music!
okay, so here is my problem: i have done this tutorial, and have had no luck....
i got all my parts from radio shack yesterday, ( Transistor, LED, switches, etc....) so they aren't old, and to make sure, I just tested the two transistors, and the still are working, same with use, battery.
I do not know what i am wiring wrong, but please help!!
here are the pictures of the wiring
Picture of Help! My Leds wont sync to the music!
LEDs the wrong way round ? In the circuit shown in the tutorial, the battery is the wrong way round.,
If the battery was reversed wouldn't that be backward for the transistors?
Hackrtanman (author)  Re-design6 years ago
no, at least i dont think so. Resistors only go one way, and that is from Base, or B, to the emitter, E, i think....then the collector, C, gets added on for more power
No, I've reviewed it again. As shown, the emitter of the NPN transistors is forced positive, and the collector negative. The LEDs are shown as emitter loads, and correctly oriented for the transistors, the power is definitely wrong. Don't let the voltage at the base go more than .7V, or you'll damage the transistors that way too.
Hackrtanman (author)  steveastrouk6 years ago
so what should i do to fix this?
Fix what ? Base resistors ? Add a 100 Ohm resistor to the base in series.
I bow to your greater knowledge!
lemonie6 years ago
You want to draw this nicely, I'm not sure which things are what, sesp. the black blob. Where is your input?
L
Hackrtanman (author)  lemonie6 years ago
sorry, the black blob is just covering up the other transistor, so pople woulndt get confused....I'll draw one soon!(well, a diagram anyway,)
tomtortoise6 years ago
Maybe you don't have the volume loud enough? Bad song choice/not a loud song?
Hackrtanman (author)  tomtortoise6 years ago
well, my ipod is on full blast, and the song choice was by the offspring, which is a rock band, and pendulum, a techno-ish rock band, so i dont think it was that
Well for starters, That's a stereo plug and I only see two connections.
The original diagram has two transistors and your's only has one.  Look at the PC earphone here.
Okay, so I just hooked up the second speaker, and the speaker works, but the lights still dont work
the plug does have a third connection, its just off the picture, you can kind of see it on the left side, its green. The plug came off of headphones, so it should work. Also, i just wanted to try using one transistor, because i wanted to make sure it work and all.
Ok but what does the third connection on the jack connect to?
the thrid connection is the other positive for the other earbud
