loading
Help with Arduino?
Hey everyone,
         I'm doing a project with the arduino and i just want an led to light if a PIR senses motion.
I am using this sensor:     http://www.sparkfun.com/commerce/product_info.php?products_id=8630
I know I have everything hooked up right, my code is just wrong.(Yes, MOTOR is used for the LED) Can someone tell me what to do? Here is the code:
//Motion Detecting Box-Second Attempt
#define MOTOR 13 //Motor connected to pin 13
#define PIR 2   //Motion Sensor is connected to pin 2
void setup()
  pinMode(MOTOR, OUTPUT); //sets the digital pin as output
  pinMode(PIR, INPUT);    //sets the digital pin as input
void loop() {
 digitalRead(PIR); //checks pin 2
  if (PIR==LOW) {
  digitalWrite(MOTOR, HIGH); //turn on Motor
 else {
  digitalWrite(MOTOR, LOW);
Willard2.06 years ago
You need to store your read value from the digitalRead(PIR) statement in a variable. All it's doing right now is reading the sensor and not doing anything with the value.  Define a variable, like pirState and include it in your void loop() like this:
void loop() {
pirState = digitalRead(PIR); //checks pin 2
if (pirState==LOW) {
else {
TerryKing5 years ago
Here's info on this with example Arduino code:
http://arduino-info.wikispaces.com/Brick-Pushbuttons%26OtherSwitches#Motion
Adum24 (author) 6 years ago
So, in the top where I have #define I also need to include PIRState? And then just add in your code? How exactly do I do that?
Adum24 (author)  Adum246 years ago
Never mind! I got it! Thnx a lot! That really helped! Man, im excited! Thank you so much!
Glad I could help. Thanks for the patch.
Adum24 (author)  Willard2.06 years ago
Hey, another question, sry. UM, are my motion sensors like really sensitive? because nothings moving and it goes off randomly. Can u tell me wut to do?
I don't have experience motion sensors in particular, but I know that some sensors can only be checked so many times a second.  Right now I'd say you're checking it more than 1000 times a second.  Lets try lowering that number to something like 10-20 times per second.
Also, I just read the description and you have to let the sensor stay still for 2 seconds for it to get a 'snapshot' of the room and then start reading for movement.
My changes are in bold.  Try it out and see if it works.
int pirState = 0;  //initiates the variable for the PIR sensor
void setup()
  digitalWrite(MOTOR, HIGH); //turns on LED until initial PIR sensor gets snapshot of the room
  delay(2000);  //let the PIR sensor stay still for 2 seconds
  digitalWrite(MOTOR, LOW);  // turns the LED off
  delay(100);  //wait 1/10second before taking readings
void loop() {
pirState = digitalRead(PIR); //checks pin 2 and saves value in pirState
else {
delay(50);  //waits 1/20second before taking next reading
All right, this works for an LED, but the motor just has a field day, spinning super fast and not stopping. As soon as I remove connections to the motor it goes back to normal.(I can tell by the built in LED on the arduino.
K, thnx. I'll try it and get back to you!
Ur welcome!
Yup, just add in the line: int pirState = 0;
That initiates the variable that is used in my code. You can't use #define for any value that will change as the program runs.
So your entire code would look something like this:
void setup()
void loop() {
else {
