Help with ST72F324 micro controller?
I need to read the software program from this chip used in control equipment . The original manufacturer is no longer in business but issued a software update before going under. I have an updated control board and if it's not code protected I can then update other equipment still currently in service. I don't want to spend to much as I'm not sure if it's readable? The control board has a 10 way programming IDC socket on board to allow software updates... so I just need to link to this by the simplest / easiest method possible.
fblaci6 years ago
Hi,
Do You get a solution for the ST72F324?
I have the same problem and until now no solution, only with desoldered controler!
Thanks
fblaci
