Help with corrupt illustrator file needed?
My illustrator isn’t open, I suppose it was corrupted, how to solve it?
clausbier2 years ago
Apply next instructions, which you can find at –
http://www.filerepairforum.com/forum/adobe/adobe-aa/illustrator/383-%E2%80%8Bcorrupted-fonts-in-illustrator-file-urgent-help-need
< Open the AI file you want to repair.
< Choose "Object" and then choose "Path."
< Choose "Cleanup." (Note: Empty text paths, stray points and
unpainted objects will be deleted.)
< Choose "Paste Remembers Layers" only if your AI file
contains multiple layers. (Note: This option is available from the Layers Panel
menu.)
< Drag a marquee around all of your artwork in the file by using the
Selection tool.
< Choose "Edit," "Copy," and then choose
"File."
< Choose "New," "Edit," and then choose "Paste
in Front." (Note: "Paste in Front" will place your artwork will
mirror the damaged AI file's).
< Choose "File" and then choose "Save." If your file
is still damaged, continue.
< Make a copy of the file and give it the same name except add the
"C1" to the end of the title. (Note: You can choose any other letter,
number or other word to differentiate it from other versions.)
< Open the first copy version, select one art object within the file,
and then delete it.
< Save the file and add a number "C2" at the end of title to
differentiate it from other copies and then reopen the file. If your file is
< Repeat steps 10 and 11 until you can identify the object that is
causing the problem.
< Delete the damaged object when you find it and then re-create it by
using either the drawing tools, reestablishing a link, or by changing or
replacing the font of damaged text.
Latest instance, which you can use it, is Illustrator Repair Kit
Free version of tool:- http://www.illustrator.repair/
