Help with iPod Classic USB Portable Charger?
-Does the adapter have a regulator to bring the 9V battery down to the proper amount of volts needed to charge the iPod?
-How much power is needed to charge the iPod?
-On the battery wire thing, which wire is negative, which is positive?
-Which wire (on the battery slot) is supposed to connect to which wire on the circuit?
-On the circuit board, which is negative, which is positive?
Specs:
-(Relying on the informational sticker on the adapter) Circuit board input: AC100 - 240V 50/60Hz
-(Relying on the informational sticker on the adapter) Circuit board output: DC5V = 200mA
-More specs in pictures
Hopefully, the circuit board already has a regulator, to bring the 9V down to a 5V, so I wanted to post this to ask the experts on 'ibles to see if it probably has a regulator or by using the pictures.. thanks so much!
If you need more pictures of anything, just ask; thanks again for helping :D
11
answers
Answer it!
Hope it goes well
-Dillon
That is the most important information.
It's fairly standard 'usb' power at 5v and near 500mA (400 in this case).
A 9v battery is a TERRIBLE power source - good for smoke detectors and that's about it, their total capacity is just rubbish.
THAT SAID
There is a regulator to drop the 9v down to 5v - some are better than others, the cheapest of which will just burn off the excess voltage so that the 9v becomes 5. Pros -- simple and cheap - cons, beyond inefficient, wastes power and your batteries already start with crap power == bad.
Watch this video:
http://hackaday.com/2010/08/03/reverse-engineering-apples-recharging-scheme/
